Tweeter upgrade (again)
Old 03-07-2012, 12:31 PM
Matthewd5's Avatar
One last stupid question, do you need to reuse the factory tweeter grill or will the jl grill keep the tweeter in place?
Old 03-07-2012, 01:34 PM
mml
mml's Avatar
i have c5 tweeters, they fit in the stock grill, and i applied hot glue to secure them. they sound great are completely hidden.
was a simple installation if this helps.
Old 03-07-2012, 01:38 PM
Matthewd5's Avatar
Ok
So the factory grill piece covers up the jl tweeter completely
Thanks again
Old 03-07-2012, 03:39 PM
mml
mml's Avatar
yup, completely.
Old 03-08-2012, 03:16 AM
fishmd's Avatar
Originally Posted by mml
yup, completely.
Any pictures?
Old 03-08-2012, 02:40 PM
mml
mml's Avatar
i'll try to take some tomorrow.
Old 03-08-2012, 04:05 PM
Matthewd5's Avatar
With the factory grills on the before and after should be identical...
Old 03-12-2012, 03:15 PM
talljeeper's Avatar
Thumbs up
So I get the ZR replacement. Just a little cleanup for proper/tight fit. My question is around the wiring. Is it just a simple disconnect and reattach? Do the OEM tweeter wires have enough length to do the R&R easily. Dash component removal?
Is removing the OEM tweeter difficult?
Thanks in advance. I appreciate your patience
Old 03-12-2012, 03:29 PM
mml
mml's Avatar
ID:	288263Click image for larger version
ID:	288264Click image for larger version
Originally Posted by fishmd
Any pictures?
here's what i did, hot glued the tweeter into factory grill, added longer wiring to the existing wire that is soldered to the tweeter.
Re: removal, small flat head screw driver, gently pry the grill assembly off, comes off really easy, the factory wires are long enough to connect to the new tweeter.
Old 03-12-2012, 03:50 PM
Matthewd5's Avatar
Attachment 288263Attachment 288264Attachment 288269
So are you using an aftermarket crossover or just the oem jeep crossover?
Quick Reply: Tweeter upgrade (again)
