Code question
Code question
2011 jeep wrangler unlimited malfunction light came on and I got the code which was P0456 looked it up and it says its a Evap purge system small leak anybody know what that is ? How do I fix it ?
Thanks
Dave
Thanks
Dave
I got an error in my 2012 that actually said "gas cap". Well, it wasn't the gas cap. I just tweaked the hose side to side that goes into the evap canister and the light instantly went out. That was almost a year ago. It's never come back on. The hose must have been not sealed well and was letting a tiny bit of air in.
Former Member
the hose I tweaked was inside the engine compartment. Drivers side close to firewall. I think the hose that went into the canister was maybe 5/8" diameter. It was over a year ago so I am not positive. Give me a couple hours and I can post a picture of it
Former Member
That would be helpful because another thread talked about a hose under the hood that I couldn't find on my 07 by the description.
here are the pics, but keep in mind this is a 2012. The hose I manipulated by twisting a bit is the one that goes into the evap canister.
Former Member
Noticed filler neck surface that mates to the cap O-ring was sort of nicked/scratched a bit and had some type of oily film/dirt on it. So went back out with some Scotch Brite pad and cleaned that all up. Then I removed the cap O-ring and rolled it over to use the opposite face. Used a Q-Tip to lightly apply the Vaseline and closed her up. No I didn't try to clear the code manually I just figured if it's cured the CEL will disappear after enough run cycles. NOT
Well after a few weeks I took her in to my mechanic for an oil change and asked him to check out system for any other source of the code. He only found a different code that was the one for a bad rear oxygen sensor-I think he said P1*** something. Replaced sensor and now no codes at all.
Wondering now if the cap work I did fixed the original code and just by coincidence that second code popped up in the month or so from the time I got the original code to when I finally got around to doing the cap cleanup.
