Sponsored by:
Sponsored by: DashLynx
Correct way to install a cotter pin..
Old 07-14-2009, 06:29 AM
Hellbound13's Avatar
Default Correct way to install a cotter pin..
This may be a silly question but is there a correct way when installing cotter pins?
I left the one end straight and bent the top one up over the castle nut. Is this correct or should I also bend the bottom one down in the other direction?
Old 07-14-2009, 06:37 AM
falconfixer's Avatar
On vehicles I butterfly them along the sides of the nut. On aircraft one end went up and over the nut and end of bolt and the other end, I bent down per tech data.
Old 07-14-2009, 07:43 AM
PeterWendy's Avatar
When you stick the cotter pin through you should have the longer tip to the top of the nut, then bend it over the top of the nut . The shorter end can be bent around the side of the nut or just cut off.
Old 07-14-2009, 07:53 AM
Is it okay to leave the bottom pin sticking straight forward then?
Old 07-14-2009, 07:55 AM
I wouldnt. Trim it and bend it down so it's flush
Old 07-14-2009, 07:57 AM
So bend one up and one down?
Old 07-14-2009, 07:58 AM
if that's the method you are using, then yes. The longer one up and over and the bottom one down and both flush. What you cotter pinning?
Old 07-14-2009, 07:59 AM
Tie rod and drag link ends on my new HD steering setup.
Old 07-14-2009, 08:00 AM
gotcha.
Old 07-14-2009, 08:18 AM
Mark Doiron's Avatar
An important consideration: Leave it bent so that when working nearby on something else, you won't hurt yourself on the cotter pin.
Quick Reply: Correct way to install a cotter pin..
