Sponsored by:
Sponsored by: DashLynx
Price on new front fender?
Old 12-10-2013, 04:55 PM
Hoonlo's Avatar
Default Price on new front fender?
I I was driving through a deep snow bank today when I discover a power pole lying in wait under the plowed snow... Cracked the top of my driver side front. Any idea the cost of replacement? Also there is a slight bend in the front bar that goes in front of the diff I hope?
Old 12-10-2013, 05:27 PM
karls's Avatar
The metal? Google pulled up the link below.
http://m.quadratec.com/products/prod...d=12502+202+07
You may want to watch for folks taking them off....but it could be a while.
Sent from my DROID4 using Tapatalk
Old 12-11-2013, 06:35 AM
Hoonlo's Avatar
No the actual plastic fender, it pushed the tiire up so hi it cracked the plastic fender. I think because it's so cold out here, could not have helped...
Old 12-11-2013, 06:41 AM
Invest2m4's Avatar
The lowest cost option is to buy someones used fenders. I'm sure you could find just the front and then you have a spare for the other side. You could also source from a junk yard.
Old 12-11-2013, 07:38 AM
Mark Doiron's Avatar
Originally Posted by Hoonlo
... Also there is a slight bend in the front bar that goes in front of the diff I hope?
Which part?
Also, X2 on the buy from someone who just installed aftermarket fenders. Is the inner lining okay?
Old 12-11-2013, 10:06 AM
karls's Avatar
The plastic fenders are much cheaper to replace and can be found very easily.
Old 12-11-2013, 12:48 PM
Lorrel's Avatar
This is true. Back in Dec 06, when I got the wife an 07JKU, I backed into a stone wall New Years EVE. Imagine that
At any rate The rear plastic passenger fender cracked. Got a replacement from the dealership, and installed for $158.99. That was back in Jan 07, but I can't believe thay've gone up alot since then.
Old 12-11-2013, 01:17 PM
karls's Avatar
I meant cheaper than that.....there are a couple sets of flares local to me (all 4 flares) for $50.
Old 12-11-2013, 02:54 PM
Hoonlo's Avatar
Tie rod and it looks good thankfully. Also the inner black piece may be cracked as one of the plastic rivets is missing along with a small piece of green plastic.
Old 12-11-2013, 03:02 PM
karls's Avatar
Ebay or clipsandfasteners.com will be your friend for those rivets and clips on the flare- they are HELLA expensive at the dealer.
Quick Reply: Price on new front fender?
