Front drive shaft 20,000
Took the jeep to the sierras for some fun and noticed in 4 low down hill over rocks off the throttle i was getting this metallic clanking sound, much like a u-joint after reading many threads on this forum it sounded like the rzeepa joint at the transfer case so i took it into Jeep explained the situation and they told me the have already replaced 5-6 in 2013+ Rubicons they agreed that was the problem and gladly replaced it. on my way home there is a very noticeable vibration over 65 from what i know on the rubi the hubs do not disconnect so the drive shaft always spins. so I crawled under the jeep and noticed there are 5 wights added to balance it and the original only had 1 The dealer agreed to take a look they are going to remove the drive shaft to see if the vibration goes away and address the problem. Has anyone ever had this problem with a replacement shaft? and can someone confirm that the front drive shaft always spins even in 2wd? leaving soon for 2 weeks to Colorado and moab dont need any problems
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
If you are lifted, you will probably need to go aftermarket. Here is a link to my experience
https://www.jk-forum.com/forums/modi...ime-ds-324359/
I will also add that disconnecting the sway bar can add to the problem because it adds more angle to the joint when you are flexing.
mine was spewing
grease from the u jount (replaced at 17,000 miles ) but mine was not wheeled and got a nice new one . no issues after that . you cant just replace u joint you need whole drive shaft . mine isnt lifted i still have the hopping feeling slightly under seat like a unballanced tire but not the tires or wheels either . ill drive it till somthing surfaces seeing cant find the reason its minor though and nothing seems to break or worsen over time . strange i have replacement ball joints and axle joints if those go at some point but never could find the reason for the slight wob wub wub feeling goin on , not the drive shaft as i thought originally . its nothing i cant live with but happens at all speeds like a flat spot on tire . but original tire on there it could be felt too. so i give up lol i was thinkin maybe the dealer towed the front wheels in to much maybe who knows but tires are wearing perfectly so my thought seems to not be that either now
