Opinions on whether to replace Dana 30 or beef it up?
I am planning out my future mods and have been going back and forth on whether I should just beef up my Dana 30 or replace it a Dana 44. I have a 2008 JKU Sahara with an ARB locker in the rear already and have done nothing else to strengthen the rear. I do not wheel hard or as often as I like since I have been in school. Now I'm graduating and will have more free time. So my question is, should I just strengthen the 30 or replace with a 44? I am basically all stock right now besides the rear locker I mentioned and rock sliders. I will eventually add a 3" lift and 35's but felt it was most important to spend the bulk of my cash on building the axles.
Thanks in advance,
David
Thanks in advance,
David
The D30 is fine with 35s and mild to medium trail use. I personally wouldn't add a locker to the D30, but I know many have. If you haven't added C-gussets I would definitely do that and then run it.
If some day you plan to go bigger save for a PR44. You can polish a turd, but in the end, all you have is a pretty turd....
Not really, Rock Krawler makes some that are only welded to the upper C where most make both an upper and lower. The RK ones are ~$30 and most others are ~$60. The upper C is the real weak point, but it's just as easy to weld upper an lowers while you're there. Some of the common ones are EVO, Synergy, and Artec. All are pretty similar in design. They are cheap insurance. I have seen bent Cs from wheeling with stock tires and even on some road only Jeeps with 33s. The real expense is in welding them on if you can't weld or have a buddy that will for .
I am planning out my future mods and have been going back and forth on whether I should just beef up my Dana 30 or replace it a Dana 44. I have a 2008 JKU Sahara with an ARB locker in the rear already and have done nothing else to strengthen the rear. I do not wheel hard or as often as I like since I have been in school. Now I'm graduating and will have more free time. So my question is, should I just strengthen the 30 or replace with a 44? I am basically all stock right now besides the rear locker I mentioned and rock sliders. I will eventually add a 3" lift and 35's but felt it was most important to spend the bulk of my cash on building the axles. Thanks in advance, David
I went with the Dynatrac Pro Rock D44 and D60's
I read everything I could find about the subject, I opted not to sleeve and gusset etc.
Matthewd5
