Plush shocks for on-road only
Sadly, there will be no offroading in my future due to some spinal injuries that continue to haunt me. I'm now looking to have the most plush, Grandma-esque ride possible. I want my Jeep to feel like I'm on a waterbed inside of a Lincoln Town Car that's driving on a road made of kittens, stacked 10 deep.
2013 2-door, no lift. I want to retain the stock ride height, with bolt-on shocks.
What do you recommend?
Read a few reviews on the Rancho 9000xl.
I've never run them, but they get fairly good feedback with the 9 position adjustability. There should be a giftcard rebate going on, and they also have a 90-day return thing, so if you don't like them send em back for a refund.
Find out what springs came on your Jeep and you may be able to go with a softer oem spring which will be cheap and easy and effective. Assuming you have the black Jeep shocks now? Running a few pounds less PSI in the tires may also help but try not to overdo that idea. Those Rancho adjustable shocks sound like a great idea as long as the softest setting is softer than stock. Adjustable suspension is the ultimate, it really helped on my Motorcycles, Snowmobiles, Atvs, and Mountain Bikes. I had a similar situation 6 years ago when I bought a 350Z convertible as a gift to myself for surviving Brain surgery. I was in a lot of pain and that car gives a lot of feedback into the steering wheel and cabin. The first change was taking off the 18 inch wheels with low profile tires and buying 17 inch wheels with taller all seasons. The smoother ride allowed me to drive the car longer and enjoy it more. I hurt a lot for about 6 months but that car made me smile everytime we took it for a ride.
If you want to get a really soft shock you can have them custom built to your specs from one of the big shock manufacturers. Bilstein, king, fox should all be able to do this for you but the price is going to be high. Finding an off the shelf shock that is going to give you what you are looking for is unlikely. Finding out things like you coil rate and the weight of you jeep will help in finding a shock that is tuned for your ride.
Sadly, there will be no offroading in my future due to some spinal injuries that continue to haunt me. I'm now looking to have the most plush, Grandma-esque ride possible. I want my Jeep to feel like I'm on a waterbed inside of a Lincoln Town Car that's driving on a road made of kittens, stacked 10 deep. 2013 2-door, no lift. I want to retain the stock ride height, with bolt-on shocks. What do you recommend?
If you contact King I'm sure you can get some adjustable shocks on both the Down and upstroke. They will come with 2 adjusters on each shock and they can also custom valve and tune your shocks to your needs. One problem with custom adjustable shocks are they are going to cost you around $600 or more per corner. I'm not sure your wanting to spend that kinda dough on some shocks for the road.
You could always get coil-overs for on road use... You would be the first that I know of to do it
The Rancho's price isn't bad, so I'll contact them to see what they have to say.
Thanks all.
