What size tires are on a 2012 stock jk sport?
#31
So to answer the question it rubs without disconnecting... You could probably stop the rears from rubbing with some bumpstops. Next time you go wheeling disconnect the fronts, it is absolutely worth it and really shows off how much the jeep can flex.
#32
I too have a tire question. I have a 2010 stock Sport S with the 17" factory alloy wheels. I found a set of 18" wheels that have the JK bolt pattern, but the tires are 35's. Does anyone here have a stock suspension that is running 35's w/o any body spacers or lifts? I know that it would be very close, but what do you think? Will it look stupid? If they will fit, I'd probably need wheel spacers for clearance behind the tire.
#33
Originally Posted by Matthewd5
what size are the stock tires that your using for comparison?
matthew
#34
#35
ok [1] matthew thanks for starting this thread and [2] just to be clear 33s ok no lift with after market rims but what do we do about the speedometer do they set that or do we need a chip reset for that? btw your guys jeeps look amazing
#36
#37
#39
Well started this thread and got a lot of interesting info
I think for now I'm probably going to keep an eye out for a set of rubicon tires when someone is upgrading and then eventually do a lift and goto 35's
Matthew
Matthew
#40
Originally Posted by killerbee2012
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=292404"/>
255/75/17 next to 285/70/17 the 255 is 32" tall the 285 is 33" tall.
