Sponsored by:
Sponsored by: DashLynx
What size tires are on a 2012 stock jk sport?
Old 03-21-2012, 11:58 AM
  #31
hypeiv's Avatar
Originally Posted by ovrthetop
Just rubs in the rear, fronts dont rub, i have a feeling the fronts would rub the fenders disconnected though.
So to answer the question it rubs without disconnecting... You could probably stop the rears from rubbing with some bumpstops. Next time you go wheeling disconnect the fronts, it is absolutely worth it and really shows off how much the jeep can flex.
Old 03-21-2012, 12:22 PM
  #32
JK-Jeremy's Avatar
I too have a tire question. I have a 2010 stock Sport S with the 17" factory alloy wheels. I found a set of 18" wheels that have the JK bolt pattern, but the tires are 35's. Does anyone here have a stock suspension that is running 35's w/o any body spacers or lifts? I know that it would be very close, but what do you think? Will it look stupid? If they will fit, I'd probably need wheel spacers for clearance behind the tire.
Old 03-21-2012, 04:09 PM
  #33
nlowe660's Avatar
Originally Posted by Matthewd5
what size are the stock tires that your using for comparison?
matthew
The stocks were the 225/75 16s. The 33s are the 33/12.50 15 Duratracs.
Old 03-21-2012, 06:56 PM
  #34
Lighting Guy's Avatar
There's pretty much no way 35's will work without rubbing I think. You would need at least spacers, and I don't think you could flex it.. at all. Someone else can chime in and correct me though.
Old 03-21-2012, 09:50 PM
  #35
joshsolo's Avatar
ok [1] matthew thanks for starting this thread and [2] just to be clear 33s ok no lift with after market rims but what do we do about the speedometer do they set that or do we need a chip reset for that? btw your guys jeeps look amazing
Old 03-22-2012, 03:58 AM
  #36
flatattack's Avatar
I was able to get the dealer to reset my computer for "33's".
Old 03-22-2012, 04:32 AM
  #37
nlowe660's Avatar
It would be worth your while to buy the AEV ProCal Module. You can reprogram tire size plus do a lot more. I just got one and I love it.
Old 03-23-2012, 01:50 PM
  #38
I've read the dealer can only do up to 32", since that's the tallest you can get from the factory.
Old 03-23-2012, 02:30 PM
  #39
Matthewd5's Avatar
Well started this thread and got a lot of interesting info
I think for now I'm probably going to keep an eye out for a set of rubicon tires when someone is upgrading and then eventually do a lift and goto 35's
Matthew
Old 03-23-2012, 04:04 PM
  #40
JKelpaso's Avatar
Originally Posted by killerbee2012
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=292404"/>
255/75/17 next to 285/70/17 the 255 is 32" tall the 285 is 33" tall.
Why is he width difference?
Quick Reply: What size tires are on a 2012 stock jk sport?
