Viair on board system
Old Oct 30, 2009 | 01:17 PM
zjk's Avatar
zjk
Default Viair on board system
I ordered the Viair constant duty on board air system, should get it Monday,does anyone have this system? where did you mount it? Do you have pic. of your install.
Old Oct 30, 2009 | 01:39 PM
Robar's Avatar
ARB High Output On-Board Air Compressor Under the Hood Installation Write-Up
Added some air
Old Oct 30, 2009 | 04:08 PM
azrockzuk's Avatar
compressor behind the passanger tail light ....
and river radier skid plate...
Old Oct 30, 2009 | 04:30 PM
jdcjeep's Avatar
I put mine in the rear cargo section of my 4DR. Hadn't seen the behind the right rear taillight install yet. The compressor is mounted to the top of the left side wheel well, and the tank is mounted to the inboard side of the wheel well. No pics. but I'll try to take some Monday and post 'em. I don't like the idea of putting the tank under the body, it'll just corrode and wear out sooner. 'Course, that might not be such a problem down there in Odessa. Good luck, and it's a great system wherever you install it.
Old Oct 30, 2009 | 08:02 PM
robin's Avatar
I wish I had one of those
Old Oct 31, 2009 | 05:34 AM
zjk's Avatar
zjk
Think's, That is where I'm going to mount it. I just order the bracket.
Do you have a air tank? if you do where did you mount it?
Old Nov 3, 2009 | 05:47 AM
CitadelJeep04's Avatar
I just got the same Constant Duty kit about a week ago, and I have been trying to get it installed too. Only problem for me is that I absolutely could NOT get the compressor to fit behind the tail light...
Old Nov 3, 2009 | 05:51 AM
tcodtj's Avatar
I mounted mine inside of my front bumper.
Old Nov 3, 2009 | 11:23 AM
zjk's Avatar
zjk
I got mine yesterday, but I ordered a mounting bracket from 4WD to mount it under the hood, like Robar did , still waiting for the bracket. where are you going to put your tank?
Old Nov 3, 2009 | 11:50 AM
midwesterner's Avatar
Tank mounted to the tub just above rear axle, compressor mounted to cross member just behind rear axle. Custom control panel mounted in back. See pics.
ID:	32395   Click image for larger version
Name:	113_1392_Control Panel.jpg
