Viair on board system
Old Nov 3, 2009 | 11:59 AM
RedneckJeep's Avatar
Originally Posted by midwesterner
Tank mounted to the tub just above rear axle, compressor mounted to cross member just behind rear axle. Custom control panel mounted in back. See pics.
Are you not afraid of compressor water damage?
Old Nov 3, 2009 | 04:54 PM
midwesterner's Avatar
The Viair compressor appears to be sealed up very well, I can't imagine any water getting in. The only weak spot I could see might be where the wiring enters the motor but it is sealed well. I have driven it thru a couple of fairly deep water crossings with no ill effects yet. Now if I let it sit submurged for a prolong period that may be a different story.
Anyone else have any issues with a compressor mounted like this?
Old Nov 3, 2009 | 06:33 PM
yellow08jk's Avatar
How about where it draws in air? I'm guessing water could get in there. And if it kicked on while you were actually IN water...
Jim
Old Nov 3, 2009 | 06:46 PM
BIGJ's Avatar
Jim
was thinkin the same thing, may wanna move the intake line up behind the tail lights or some place like that up high.
Old Nov 3, 2009 | 06:50 PM
w squared's Avatar
Originally Posted by azrockzuk
compressor behind the passanger tail light ....
and river radier skid plate...
How do you bleed down the air tank and release the condensation when it's inside that skid plate?
I like the design, but that question just occured to me.
Old Nov 3, 2009 | 07:53 PM
Jim
No worries there; the intake is plumbed to a filter that is mounted behind the tail light.
Old Nov 4, 2009 | 03:35 AM
Schantin's Avatar
That's a nice clean install.
Old Nov 4, 2009 | 08:55 AM
yellow08jk's Avatar
Groovy
Don't you like the SHTF smiley though?
Old Nov 6, 2009 | 08:37 PM
whpony96's Avatar
OK here's my setup..
First having the tank or compressor exposed to the elements was not a option. I did not want either to have the potential to get damaged by weather or off-roading. Second it could not take away from the amount of usable cargo interior space from the inside of the JK. And last of all it could not obstruct the ability for me to switch between the hard top and the soft or any functionality of either. So this is what I came up with....
ID:	32514   Click image for larger version
ID:	32515   Click image for larger version
ID:	32516   Click image for larger version
