KC HiLiTES Brand-New Gravity LED Series Lights
KC HiLiTES has announced a new LED Light product for 2014: the Gravity LED Series. It uses a new, patented Gravity Reflective Diode (GRD) technology for improved precision thanks to proven reflector optics. The GRD Technology uses two 10-watt LEDs angled towards the reflector, maximizing their effectiveness and amplifying the amount of light that gets projected. It makes for an extremely bright, but highly efficient light that provides greater distance vision.
What’s great is that the six-inch Gravity LED is designed as an insert to replace the six-inch halogen Daylighters and halogen Pro-Sports lights for a quick and easy upgrade to LED lighting. The inserts are rated to IP68 with a fully self-contained LED, lens and reflector. It’s plug and play, so there is no modification needed to make the Gravity work in the Daylighters and Pro-Sports lights. They will be available in spot- or spread-beam patterns in individual or paired packaging.
The Pro-Sport Gravity LED will put prepackaged GRD technology into the Pro-Sport’s compact and impact-resistant Polymax housing. These will be available in spread- or spot-beam and single or paired lights with protective KC stone guards and wiring kits with weather-proof plug connectors.
Finally, GRD technology will be available in KC’s four-inch by six-inch Gravity LED Driving Light. It features an IP68-rated aluminum housing and is perfect for a variety of mounting areas. You will be able to get these driving lights in individual or paired packaging and with stone guards and wiring kits.
