Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
Can you fit 255/75R17 on 97 Cherokee
Old 04-01-2008, 09:23 AM
davefollower's Avatar
Default Can you fit 255/75R17 on 97 Cherokee
Does anyone know what the largest rim/tire combo you can fit on a 97 cherokee witout any mods. Can you fir 255/75R17's ?
davefollower is offline
Old 04-01-2008, 11:54 AM
Red Rubi's Avatar
I had 33x12.5x15 on a cherokee with 6" lift and no trimming, coud have fit 35"s. The tire you listed is about a 32x10x17. A 225/70/17 (29.5x10x17) would be my guess at most, but that's still pushing it. Maybe a 225/75/17 (30x9x17) with alot of trimming if you plan on going offroading.
Red Rubi is offline
Old 04-03-2008, 07:49 PM
Thanks for the info
Old 04-22-2008, 05:12 AM
Jsr
Jsr's Avatar
You can fit p255/75 r15 on a cherokee without any modification I
I have a 1997 xj sport after the stock wore out that is the size I went afterward.
Jsr is offline
Old 04-25-2008, 05:18 AM
DFW Rusty's Avatar
My buddy had 31"x 10.5" M/T's on his Cherokee, with 1/2" coil spacers(the cheap twist in kind from Autozone), and lifting shackles in the rear(1/2" lift approximately).
DFW Rusty is offline
Old 04-29-2008, 08:53 AM
mtruckstuff's Avatar
A 255/75R17 tire is approximately 32 inches in diameter and 10 inches wide at the sidewall. 31's on the Up Country suspension (my case, 1" lift) rub at the control arms and flares.
A 255/75/15 tire is approximately 30.5 inches in diameter (same width) and I suspect it also would have a rub issue somewhere.
You could do this 17" tire with a 2" budget boost and probably still have to correct for control arm rub. No off-roading though. You'd be better off going with a 4" lift. They haven't come out with many tires suitable for off-road use in this rim size. Why would you do this anyway? The Cherokee would ride rough as a cob with them.
Sell the tires (IMHO Wranglers(Goodyear not Jeep) are junk anyway)you have left over from your JK for a couple hundred and use it toward a set of 30/9.50/15 Yoko ATS for the XJ. These will fit without mods and ride/look better than stock.
mtruckstuff is offline
Quick Reply: Can you fit 255/75R17 on 97 Cherokee
