Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
My WK
Old 10-31-2007, 11:29 AM
ctate's Avatar
Default My WK
This is going to be the first Jeep that I'm lifting so I don't know too much about doing it. Its the WK 07 Grand Cherokee CRD 3.0. I'm just going to lift it with a ARB 2.25" kit and am going from a 245/65r17 size tire to a bigger 265/70r17. Am I going to lose any power with a diesel engine and how will it effect my gas mileage? Also, am I looking at possible transmission damage? I would love any feedback.
ctate is offline
Old 11-04-2007, 09:33 AM
bodybrdng's Avatar
I did a lot of research for you and couldn't find anything. Sorry
bodybrdng is offline
Old 11-04-2007, 12:51 PM
yellowjeeper85's Avatar
i would imagine you would feel a slight loss of power and see a small decrease in milage. However, the jump up in tire size isn't that big that you should see any transmission damage. Good luck with your project, i hope you post pics when you're done..... never seen a lifted WK before.
yellowjeeper85 is offline
Old 11-11-2007, 08:36 PM
ditto on yellowjeeper85's comment...
REDR0CKJK is offline
Old 11-12-2007, 08:27 PM
usgaone's Avatar
To be honest with the beast that the CRD is I doubt you notice much difference. As for damage to the transmission, with the tire change it shouldu be a none issue. Have a similar lift on our Commander and it's a nice different stance. The only thing is you'll run into a bit of a clearance issue with stock rims. Need a slight different offset on teh wheels, or use a wheel spacer, minimum you need is 1.25".
usgaone is offline
Old 11-18-2007, 12:50 PM
a commander with a lift... my dream come true... i'd love to pics of that too.
Old 11-21-2007, 08:31 AM
shredX's Avatar
I just traded my JK for an 08 Jeep Green Commander Overland. On order I have a 2.25 Rocky Road lift, 1.5 Spider Trax spacers and 265/70/17 BFG AT.
Of course I'll post pics.
As far as the CRD and lift and tires... Your drive train will be fine. You're only increasing tire size a little over an inch. Depending on tire weight, you should not notice any difference with the CRD.
shredX is offline
