CenCal If you live in Central California and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Can anyone recommend a good shop?
Old Nov 24, 2011 | 07:49 AM
ChopN's Avatar
Originally Posted by jeepsanddrums
For the popping sound I would start by checking the front track bar. I've also heard sway bar links and front axle u-joints make popping noises.
U joints sound like it might me it. Everything else looks good. Anyway to visually check?
Originally Posted by BONDSY
Is your diff leak coming from the diff cover or from the end on the axle tube near the tire? Front diff or rear?
End of rear drivers side axle. It's all over my brakes and inside of wheel.
Thanks for responding guys. Anything helps. Happy thanksgiving!
Old Nov 24, 2011 | 01:34 PM
Its_a_JK's Avatar
Sponsoring Vendor
Epic-Addictions Representative
Did you recently switch to synthetic? I have heard a lot about the thinner synthetics leaking and when changing back the leak stops.
Old Nov 24, 2011 | 05:40 PM
ChopN's Avatar
It's been leaking since the factory diff fluid was in.
Old Nov 29, 2011 | 10:00 AM
ChopN's Avatar
Well good news. I just greased up the trackbar and sway bar links and that took care of the front end clunk.
I'll have the dealer in monterey look into the coolant issue cause I didn't have a friendly experience with the dealer here. But after driving a lot this weekend it seems to be fine for now.
Only thing is the leak out of the rear driver side axle. I checked the diff level and it was still full so it's a slow leak. It has been leaking since before I changed the diff oil. When I changed it the original fluid was filled way over the plug and made a big mess. Looking into some threads here it seems to have happened to a few people where it was overfilled and caused a leak.
Is there a write up anywhere here that explains the process to replace the seal? Will I need to rent any special tools like a press? I'd like to take care of this myself and learn something.
