Central Canada If you live in the Ontario or Quebec area of Canada and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
DW holy $hit
Old Jan 14, 2010 | 07:07 PM
-MAW-'s Avatar
Default DW holy $hit
Well got death wobble today and let me tell you I've rolled my parents minivan going 110 on the hwy and that wasn't nearly close to how this made me feel. I was only going 20 on a really bad road on my way to work and she went nuts lucky for me their was no on coming traffic and no one behind me only lasted 20 seconds best thing to do is put her in neutral and brake to a stop. It appears to be tracbar related because everything else is tight and torqued to spec but the bushing axel side seems to be compressed and deformed will re install my oem one and test her out tomorrow morning. But guys I strongly suggest that we check our shit out because DW is one of the scariest and dangerous things I have ever experienced first hand.
Old Jan 15, 2010 | 04:37 AM
scbesse's Avatar
Glad you didnt get hurt. Good reminder thanks
Old Jan 15, 2010 | 05:02 AM
Trick Cyclist's Avatar
Glad to hear that you're OK. Thanks for the heads-up. Had a worn trackbar busing (axle end) in the Fall - no DW, just very flighty steering.
Old Jan 15, 2010 | 05:19 AM
Yoda's Avatar
Sorry for you Matt; I know what it is because I had DW many times on my old JK
If you re- install your oem tracbar, your axle won't be centered anymore with your 4" lift...
If I were you, I would check also your toe-in, caster, ball joints, pitman etc
Good luck
Old Jan 15, 2010 | 10:09 AM
-MAW-'s Avatar
Well changed the t bar and re centered the steering wheel a lot better but I would say that the bushings were done on the axel side. I would say it is now a real bad shimmy brought to my neighbors dealership told them check
Balance
Ball joints
And my toe
Old Jan 16, 2010 | 05:46 AM
Zebco99's Avatar
I still have DW since Chertsey in Nov.. Dave and I went to the US yesterday to pick up some loot and as he was driving we hit a small hole on the drivers side about 60km and nuts it went.
I thought it was fixed after I had the wheels rebalanced last week and that took care of the wobble (so I thought). I peeled off a few weights up in "the Bob" and being statically balanced I couldn't see any missing.
Anyway glad you are OK Matt... I do know how scary it can be..
Zeb
Is it my imagination, or do buffalo wings taste like chicken?
Old Jan 17, 2010 | 04:58 AM
Yoda's Avatar
That's the reason why I didn't put a 4" lift kit on my second JK.
4" is high, and the JK is more vulnerable to DW. Even more with 35" tires.
Old Jan 17, 2010 | 10:32 AM
-MAW-'s Avatar
I have a TF BB Daniel , I don't know why you think I got 4in lift
Old Jan 17, 2010 | 10:35 AM
07crawler's Avatar
I am about to get a 2.5" coil lift...what is the cause or when does this DW start? after a lift? and how much of a lift?....
Old Jan 17, 2010 | 10:44 AM
-MAW-'s Avatar
You can get dw on a stock jeep, this being said the bigger you go the more prone you become. My only recommendations are build her up tough.
