Bumps me out to login
Old Feb 23, 2015 | 07:28 PM
GW in little rock's Avatar
Default Bumps me out to login
This has happened 3 times to me. I login and go to profile and try to send private message . This is hard on the iPad because it gives a tiny window to write in that you can't view the whole message. Then I try to preview the post and it tells me I'm not logged in, so I login again and return back where I was and my message is gone .this is not worth the effort or maybe I'm doing something wrong.
Old Feb 24, 2015 | 03:46 AM
speedlimit's Avatar
Hi,
That should not be happening, I checked 'under the hood' and your account is fine. Did it occur on your desktop or mobile app? What browser and OS, thanks.
Bob
Old Feb 24, 2015 | 09:01 AM
Originally Posted by speedlimit
Hi,
Bob
I replyed to you in private messages but found your reply here.i do have an iPad Air 2 using chrome.
But this is just happened here.i went back to desk top to see what I was using and it made me login here just now and it stole the reply .So if you go outside of forum does it make you log back in? Just trying to learn this. A lot of good information and good people here.
Thanks
GW
PS I used preview this time and it worked so far hope it will send .
Old Feb 24, 2015 | 09:51 AM
speedlimit's Avatar
Red face
Hey,
As I mentioned in the PM, the Quick Reply box does not offer a Preview. Simply select 'Go Advanced' for all edit features. You should not have to log in every time from the SAME device if you check 'Keep Me Logged In'. Each device has it's own set of cookies, make sure your browser is set to accept them. I hoped this helps.
Bob..
