Buying Rims
Old Oct 16, 2013 | 04:42 PM
RichieBoo's Avatar
Default Buying Rims
What size fits on a 2013 wrangler sport unlimited... no lift... thanks for the help...
Old Oct 16, 2013 | 05:11 PM
kh202's Avatar
Wheels??? Anything 16" or bigger with 5x5 bolt pattern. Some 15's fit.....
Old Oct 16, 2013 | 06:19 PM
RichieBoo's Avatar
Thanks... thinking 16 or 17 inch but can it be 17 by 8 or 17 by 9..i think I see 4.5 spacer or 5 spacer... does it matter.
Old Oct 16, 2013 | 06:27 PM
kh202's Avatar
16's will save you some money on tires, and make the tires look a little beefier. I'd recommend a wheel with 4.5" or less backspacing for clearance. 8 or 9" wheel would work fine for 12.5" wide tire. I myself run 8" wide
Old Oct 16, 2013 | 06:50 PM
RichieBoo's Avatar
Thanks.. im going with 16 by 8... now for the tires what would you recommend.. thanks for all the help..
Old Oct 16, 2013 | 07:05 PM
kh202's Avatar
That all depends on your budget, lift, wheeling plans, gears, gears... Need much info
