Forum keeps crashing..
The Android app still does not display the photos or thumbnails consistently. Seems randomic and I could not isolate the cause.
Repro steps are still:
1) run app - in my case, Honeycomb in an Acer A100
2) login
3) open any thread with photos - thumbnails not displayed - expected: should display as before changing servers
4) touch any thumbnail
4) app opens new screen
5) new screen displays a "ribbon" of placeholders for photos on top but no thumbnails or photos even if I scroll - expected: should display thumbnails and the photo of the highlighed one
Hope this helps.
Still could not figure out how to get the hops count on the Android device.
Will open my PC, since should not make a difference.
2) login
Hope this helps.
2) login
Hope this helps.
2) login
Hope this helps.
Images are all working for me, check this screenshot:
Originally Posted by Robb M.
Could you possibly try uninstalling, then reinstalling the app?
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=277710"/>
Tried unistalling and then reinstalling. Same result. Still a random behavior.
I go to some threads and it works. I go to others, does not work. Then I go back where it worked and now does not work. Then it works in they other it did not work before.
For example, your screenshot's thumbnail does not show in the thread. If I touch it, the other screen shows up and I still do not see the thumbnail, but see the photo. In other cases I can see thumbnail and photos.
I want to work through this with you guys, i don't understand the apparent randomness of it at all.
Could you post some links in this thread, to threads where you have thumbnails that do show up, and some threads that they don't show up, so that I can see how they behave for me please?
cheers,
robb
cheers,
robb
Delete this one. The iPhone app was actually pulling more than one photo. Seems to be OK now.
I'll check back on the Android one later at home using the tablet.
I spoke with Internet Brands and was told that it would be helpful if you could provide any additional information such as:
• What operating system, browser & version are you using?
• ISP info and connection type?
• Issue experienced such as low loading page, slow connecting, then good load, connection reset errors, 404s, etc. Also, the action being performed when this occurred.
• If you know how, is there a chance you could do a trace routes to this site - that would be helpful.
Thanks your help!
Thanks your help!
I thought it was bandwidth congestion at first, but now think they did a bad patch on their database.
You might want to ask them if they did a software update in the past 7-10 days.
They have logs - they just need the motivation to look at them.
