Help, Newbie Steering Problems,search problems
Im trying to search existing posts for steering wable on 2007 rubicon with Rubicon express 2.5 lift /33" tires, but keep getting this error,"received zero-sized searchd response"?? What am I doing wrong in search box?
Not sure what's going on right now with the search function
... this thread may help get you started:
https://www.jk-forum.com/forums/jk-w...obbles-260145/
... this thread may help get you started:https://www.jk-forum.com/forums/jk-w...obbles-260145/
Probably need a new steering stabilizer. That's the shock in front of the front axel that lays horizontal. You can get a good one for less than $100.
~JDub
Sent from this Dang Thing
~JDub
Thank you, I did replace stabilizer a few weeks ago, and ball joints. Its better but not fixed. I think maybe its the track bar. 126,000 miles on the Ruby.
Try sucking the fluid out of the power steering reservoir with a turkey baster or whatever you can use. Fill it back up. Then start the jeep drive around a little turning the wheel back and forth and repeat the process like 3 times. I had a wobble replaced the universals in the axle ( didnt help) then did this and it stopped
