noise after spark plug change
Old Apr 1, 2019 | 10:53 PM
jmoore29's Avatar
Question noise after spark plug change
Hello all,
I just did a spark plug change on my 2013 jeep jku 6 speed due to a misfire in cylinder 2 code (p0302). I have noticed a noise like a knock/tick while in idle and a little while on the gas. it idles at a good rpm just sounds rough. are there any thoughts as to why this is happening? I believe it could be because a possible coil pack isn't fully engaged with the plug and the arc is jumping but there are is no longer a check engine light and no code for a misfire. would this problem throw a code for misfire?
Thanks for helping!
