"Participated" not working in iOS app
Old Aug 1, 2012 | 02:30 PM
J1000's Avatar
Default "Participated" not working in iOS app
I realize this is probably just a branded version of Forum Runner, but this function isn't working in the app. I have essentially the same app for other forums and have no problems with them. Tried logging out and back in, refreshing, etc, to no avail.
Old Aug 1, 2012 | 03:56 PM
JKU2012PA's Avatar
I"m having the same issue with my iPhone 4.
Old Aug 1, 2012 | 04:23 PM
SBEII's Avatar
My Iphone 4 hangs up sometimes and requires turning off the phone and tuning it back on to get the app to function properly.
Old Aug 1, 2012 | 05:14 PM
JamesWyatt's Avatar
Same here with the "participated" not working at all. Also as mentioned in another thread, many images in posts show broken link icons; and some images that do work still show an error message across them.
Old Aug 2, 2012 | 02:16 PM
J1000's Avatar
Interestingly enough, this thread shows up there now, but no others. I just realized Tapatalk is enabled though, and that is working fine.
Old Aug 2, 2012 | 02:25 PM
keithvegas's Avatar
I'm pretty sure participated only works for threads you start. If you go to the more button and the subscribed it should show you anything you participated in.
Old Aug 3, 2012 | 04:21 AM
J1000's Avatar
Nope, all the other forums I have the same branded app for list any threads I participated in, not just the ones I started. Anyhow, since Tapatalk works, I'm just gonna use that. I have 4 other forums setup in it anyhow.
Old Aug 3, 2012 | 09:48 AM
keithvegas's Avatar
Yeah, I know how it is supposed to work, I was explaining how it works in this app. I didn't know Tapatalk was working again. I thought it was disabled a few months ago.
Old Aug 3, 2012 | 10:01 AM
JamesWyatt's Avatar
I think the point is that since other forums use the same app only with different branding that it should be working correctly. It's a configuration error or something else on the server/forum software side. It's not just the "participated" that's jacked, it's half the images show up as broken links, and some images that do show up have an error message displayed across them. The forum software probably just needs to be updated to the latest version if it's not already. If it is, then there might be configuration changes that could be made to the forum settings on the server that would allow it to work correctly with the iPhone app.
