Phoenix Area JK'ers Say your piece!
#8031
In Mesa I would recommend let's roll offroad.
#8032
I have had real good luck with Jason at Absolute Offroad. Only problem for me is he is up north.
What prompted you to go to a PSC system? I only ask becouse my 2010 2door JK is acting starange at low RPM. My power stearing seems to "Fade" on me.
Running 35's with about a 3.5 lift and a ton of crap added to the Jeep.
#8033
#8034
I am running the PSC. Not terrible to install but it is a lot of work. Swapping the steering box and welding the axle side mount is the most difficult. Do you already have an aftermarket tie rod? Do you plan on using a clamp on the tie rod or welding tabs to it?
Not sure on the clamp or welding tabs which is better?
#8035
#8036
Well I started with tabs welded on. My tie rod is made of 250 wall chromoly and I thought it was unbendable but I was wrong. I recently changed to a clamp so I can spin the tie rod when I bend it. I put a small weld on each side of the clamp to keep it from moving.
#8040
