JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Gladiator Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/gladiator-electrical-lighting-sound-systems-257/)
-   -   Aux pre-wired switches (https://www.jk-forum.com/forums/gladiator-electrical-lighting-sound-systems-257/aux-pre-wired-switches-352288/)
Sunnysideup Nov 10, 2019 09:59 PM
I installed an extra 12 volt outlet on the passenger side under dash... I ran the ground wire to the body ground right behind the door removal panel, ran the hot wire to the harness to the orange pink wire... instant fused power! I fished the gps wire behind the dash... plugged it into the new 12 volt under dash- and have it come out on top from the windshield, all hidden! ...and have power at the press of the button! You can also use the head unit to change it to have power available with the ignition off, or all the time... it was a pretty fast way to set up a multi-use power option! Just one of the cool things you can order on your gladiator! I know this was available on the JL as well... it just was so nice to have that all wired and set up for you!
Mark Doiron Feb 8, 2020 11:35 PM
And way less expensive than an sPOD. In my Gladiator, I've wired two of my switches, one to power on the ARB Twin Air Compressor, the other for primary power to the radio rack ...
https://cimg5.ibsrv.net/gimg/www.jk-...d86ed0f24c.jpg
https://cimg8.ibsrv.net/gimg/www.jk-...273af2f732.jpg
© 2026 MH Sub I, LLC dba Internet Brands
