Great Lakes If you live in the Great Lakes area (Minnesota, Illinois, Wisconsin, Michigan, Indiana and Ohio) and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
5x5 bolt wheels
Old Mar 2, 2009 | 01:00 PM
bsdenney's Avatar
Default 5x5 bolt wheels
hey i was wondering if anybody knew if there where any other vehicles that had wheels that would fit on our jk's
Old Mar 2, 2009 | 01:42 PM
dburgette's Avatar
Here are two:
Pacifica 04-up
Grand Cherokee 99-up
Wings fan's Avatar
Hummer H3 also
Old Mar 2, 2009 | 01:44 PM
tcodtj's Avatar
chevy 2wd pickup pre 1999
Old Mar 2, 2009 | 01:49 PM
bsdenney's Avatar
Default 5x5 wheels
thanks a lot guys i'm tring to put together a trail wheel and tire package. will a 33x12.50 fit with no lift?
Old Mar 2, 2009 | 03:42 PM
Wings fan's Avatar
Yes but will rub at full flex how much depends on your BS. I run(285/70/17) 5.75" with no rubbing but its because the BS allows the tire to tuck into the fenders. When you start running less BS 4.5 or 4 it will rub with no lift at full flex. Then if you don't want to lift it you will need to add bump stops or pick up a set of stock flares and cut them to allow for the flex.
IMO I like a 15" rim for trail tires allows for a great pattern when aired down.
Old Mar 2, 2009 | 05:14 PM
dburgette's Avatar
Great advice Wings fan! I have the 15" wheel and have been extremely impressed with the grip and pattern. I plan on cutting my fenders when the weather starts to warm up. That will solve some rubbing issues with my backspace. There are so many factors that go into wheels/tires/rubbing.
Old Mar 2, 2009 | 06:53 PM
bsdenney's Avatar
thanks again guys. I was kinda looking into a 15".
Old Mar 3, 2009 | 08:20 PM
Kachad's Avatar
I was thinking of 15" as well, but ended up getting 16". Still alot of good rubber, and it seemed like there might have been a better selection of wheels out there without worrying about the calipers rubbing.
