Great Lakes If you live in the Great Lakes area (Minnesota, Illinois, Wisconsin, Michigan, Indiana and Ohio) and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
leaking Rear Diff cover
Old Feb 18, 2010 | 05:26 PM
Hitch Buddy's Avatar
Default leaking Rear Diff cover
What shoud I do Take off the rear diff cover and reseal it or tork the sucker down.
I have never taking the cover off yet so why is it leaking ? oh well waiting to hear from the pro's
Old Feb 18, 2010 | 05:34 PM
pulman01's Avatar
I would try torquing them down to 25ft/lbs (double check the specs) first, then move on to the next. I too had a leaky rear diff cover and the only thing that worked was a lube locker gasket.
Old Feb 18, 2010 | 07:28 PM
jmat1980's Avatar
Might as well take it off, clean the gears, re fill with synthetic, order some diff covers re seal and replace...
Thats what I would do
Old Feb 19, 2010 | 02:34 AM
Dex1's Avatar
Use the excuse to take them off, inspect the gears, buy some heavy duty covers, and refill with some good synthetic lube....
If you have never taken them off, now would be the time to do it, before the summer season gets here.....
only takes a few minutes to do it, good maint. practice anyway...
Old Feb 19, 2010 | 04:48 AM
Cpt. Flapjack's Avatar
Machine154's Avatar
I kept fighting leaks, taking it off and re-RTVing. If you're offroading a bunch, I think the lubelocker gaskets are the way to go. They seem to be more tolerant of movement.
Old Feb 19, 2010 | 05:16 AM
dburgette's Avatar
I think everyone pretty much nailed the fix. Take it off and lube or seal it yourself. It won't take you long.
Old Feb 19, 2010 | 05:32 AM
You guys mention cleaning the gears....With a spray cleaner?
Last time I Changed Diff fluid I used full synthetic I plan to do the same this time.
I'm getting it ready for Moab.
Old Feb 19, 2010 | 05:39 AM
rich1340's Avatar
When you retorque don't forget to tighten the bolts in a cross cross pattern like when you put on a wheel.
Old Feb 19, 2010 | 06:20 AM
rich1340's Avatar
Yeah.. brake cleaner works great. If you get the non flammable type make sure you dry it off really well. Otherwise it can degrade the lube. Afterall, it is a solvent. The flammable stuff evaporates quicker.
