Jeep CJ, Jeepster & Willys Overall Jeep CJ, Jeepster and Willys technical discussion bulletin board forum. This includes pretty much most Jeeps made between 1955-1986.
350/700R4 conversion
Old Dec 20, 2009 | 04:07 PM
pulman01's Avatar
Default 350/700R4 conversion
Just dropped off my 85 CJ7 for a 350/700R4 conversion. Hopefully will have some pics soon. I found a donor 93 GMC, just waiting to go check it out.
Old Dec 28, 2009 | 08:48 PM
JKOperator's Avatar
What's the plan for the rest of the drivetrain? (T/C, Fr/Rr diffs, gear ratio and tire size)
Old Dec 29, 2009 | 04:32 PM
pulman01's Avatar
I am keeping the Dana 300 T/C, and looking for some 1 ton axles right now. I plan on running 35's, so may just keep the stock gears in the 1 ton's (4.10's?). I just dropped off the donor, so it should be starting real soon. I plan on helping out on the weekends and will take some pics.
Old Dec 29, 2009 | 06:45 PM
JKOperator's Avatar
'93 GMC, should be a TBI? Are you planning on running it? What wiring harness do you plan on using?
I'm building my '75 CJ6 with a '95 Chevy Sub. TBI 350 with a reverse manual valve body TH350 trans. Dana 300 Twin stick w/ a Lo Max 4:1 low range gear set, J.E. Reel shafts to Dana 44 Fr & Rr w/ 4.88 R & P Detroit Lockers in both w/ Superior Axles turning 35's. Hoping to have it ready for the Moab Easter Jeep Safari 2010.
