Jeep CJ, Jeepster & Willys Overall Jeep CJ, Jeepster and Willys technical discussion bulletin board forum. This includes pretty much most Jeeps made between 1955-1986.
Dana 300 rebuild
Old Nov 16, 2010 | 11:40 AM
jeepmedic's Avatar
Default Dana 300 rebuild
I need to pull my D300 for rebuild. The shift rails are froze and there is no power transfer from the trans to T-case.
Any tips ??
Oh yeah, 81 CJ5, SR4 trans and D300
Old Nov 16, 2010 | 12:01 PM
Bustabizz's Avatar
Former Member
Could be a number of different things. I would just pull it out and drain the oil. Crack the case open and check out the guts. Could be an issue with the input shafts or the case could be bounded up in neutral.
Old Nov 16, 2010 | 03:43 PM
jeepmedic's Avatar
sweet thanks
Old Nov 17, 2010 | 10:23 AM
Bustabizz's Avatar
Former Member
Oh and Replacement parts
http://www.4wd.com/HardParts/HPDetai...D=24&hpDID=125
Old Jan 9, 2011 | 07:20 PM
albatros_3's Avatar
If you're going to go for a full rebuild, I recommend going with a Novak kit:
http://www.novak-adapt.com/catalog/dana_300_parts.htm
They're very helpful and be sure to read the instructions and how parts need to come out and go in.
It's one of the easier things I've rebuilt, IMO. You'll need a good press.
edit: If your shift rails are froze, your linkage may just need to be taken apart and cleaned up. Happened to me a few times. Sounds like your case in stuck in neutral if there is no power transfer. You can support it with a jack, drop the skid plate, drain the oil, drop the bottom pan and inspect it if you really don't want to pull it out. But for any major work, it would be better to pull it out and work on it on a bench.
Old Jan 25, 2011 | 04:23 PM
jeepmedic's Avatar
had it rebuild. Had a bad bearing, bent shifter rail fork thingy. All better now Thanks for all the help.
