Jeep CJ, Jeepster & Willys Overall Jeep CJ, Jeepster and Willys technical discussion bulletin board forum. This includes pretty much most Jeeps made between 1955-1986.
Tj flares on a cj?
Old Nov 28, 2007 | 07:49 AM
Nlrwhiterubicon's Avatar
Default Tj flares on a cj?
I have seen some different cj's with tj flares. How hard is it to do?
Old Nov 29, 2007 | 10:05 AM
Renegade's Avatar
I put the flares from my '98 TJ on my '82 Scrambler. It wasn't too hard to do at all. I put the flares up against the Jeep as a template and marked where I wanted to cut. After cutting, I put them up again and marked the mounting holes. It worked out nicely, but the front flares didn't quite match the contour of the front fenders.
Old Nov 29, 2007 | 07:44 PM
Thanks for the help
Old Dec 4, 2007 | 12:25 PM
BLKRUBI's Avatar
Not too difficult. I basically did just like Renegade did.
Old Dec 11, 2007 | 08:26 PM
amc78cj7's Avatar
Bushwacker TJ pocket flares on a CJ7 or CJ8 can be pretty easy, although I hated them on my CJ7 because they were too hard and fragile. The biggest problem folks run into (especially with a shorter CJ such as a CJ5 or under) is that the flare mounting runs into the inner wheel well so you have nowhere to screw. A buddy put TJ flares on his CJ5 but had to cut and relocate part of the inner fender.
Old Dec 30, 2007 | 07:57 PM
CIJeep's Avatar
Back before there were all the fancy plastic flairs we used the rubber edging/molding for walls were the walls met the carpeting. They have a built in edge curve and we screwed them to the fender edging with a metal strip over the rubber edging.
Kept us legal with the coppers, was flexible, not likely to get torn off and inexpensive if it did.
