Jeep Recycler If you've got a Jeep that you want to sell or are interested in buying a used one, this is the forum for you.
2010 Jeep Wrangler | 40s | RIPP Supercharger | King Shocks
Old 05-16-2017, 12:27 PM
bhardy's Avatar
Post 2010 Jeep Wrangler | 40s | RIPP Supercharger | King Shocks
[IMG][/IMG]
----- 51k, Accepting Reasonable Offers -----
----- Text me at 720-675-9440 -----
Here's some links to the Jeep crawling stuff..
https://youtu.be/5OABVJWlISc
https://youtu.be/YAkVPYEerRg
https://youtu.be/C7n62inl-CE
2010 Jeep Wrangler Sport - Mango Tango - 3.8L Engine (75,100 miles)
Ripp Supercharger w/ Intercooler – 22 MAX PSI
Ripp Headers, Flomaster Muffler
ATS Diesel Rebuilt 42RLE Auto (fresh 50 miles)
Atlas 4 Speed w/ Shot Peen Bearings 2.72:1 / 3.80:1 / 10.34:1
Rock Krawler Deep Sump Transmission Pan
Royal Purple Fluid: Motor Oil, Power Steering, ATF, Coolant Additive, T-Case, Gear Oil, Blinker Fluid Since Day One
Dynatrac Pro Rock 60 F/R
  • 5.38 Gears
  • ARB Air Lockers
  • Full Float Rear
  • Front CTM Dana 60 U-Joints
  • F/R Comp 4340 Chromoly Shafts 35 Spline
  • HD Rebuildable Ball Joints (Front) FK Inner Bearings
  • 5 on 5.5” Stud Pattern
Front/Rear Shocks
  • King Triple Bypass 2.5” - 14”
  • King Coil over’s 2” - 14”
  • Phlexor Shock Tower and Axle Mount
  • Rock Krawler Package Coil Springs in Rear
King Rear Adjustable Performance Shocks
King 2” Bump stops Rear / EVO Mount
Rock Krawler 5.5” Solid Steel Lower Links Bushings/Joints
Rock Krawler Heims/Flex Joints or FK Bearings on all Links/Tie Rods
J.E. REEL F/R Driveshaft’s, Canyon Crawler Rear, Spicer U-Joints
1.5” 6061 Solid Aluminum Tie Rod with 3/4 FK Heim Ends
AntiRock Front/Rear Sway Bars
Spyderlock Bead lock Wheels
Fab Four Bumpers and Sliders
Bushwhacker Fender Flares
PSC Hydro Assist w/ reservoir and cooler
Poison Spider JK Sport Cage
Optima Battery w/ Dual MOORE Off-road Tray
Warn 9.5ti Winch
Master Pull Superline 7/16 – 36,500lbs winch line
Ridged Industries 50” White – 10” Amber
Street Glow Orange NEON rock lights
Truck Lite LED Headlights
Putco Brake/Reverse/Marker/Interior LED Lighting
Auto Meter 30 PSI Boost Gauge - ATM-4776
Midland 4 Watt CB Radio w/ K40 (1-2 Mile Range)
Vertex 50 Watt VHF - VX2200 (18 Mile Range)
Lowrance HDS-7 Gen2 Touch - Sirius Weather/Music/Bluetooth
Lowrance Sonic Hub / Alpine Speakers / Bazooka 250 Watt Sub
Goodyear MTR Tires 40”
2011+ Mopar Front Windshield
2011+ Hard Top
14 Fused Switches (one of which is available to tap into for another device)
Wi-Fi accessible Blackvue DR550GW 1080p Front/Rear Dash cam (24 hours of storage total???)
NEW in box Replacements
Front/Rear Comp Chromoly Axle Shafts
Front J.E. REEL Drive Shaft
2 Sets of 5.38 Ring and Pinions
PSC Power Steering Pump
PSC Hydro Ram
x2 CTM Dana 60 Joints for front
NEWISH Rear J.E. REEL Drive Shaft - (1000 miles)
New Ball Joint Housings, need FK bearings
Extras Included
Best Top Bikini Top
Best Top Rear Cover for Cargo
x4 Small Mickey Thomson Wheels/Car Tires for emissions
Custom Brackets and Mounts:
5 Piece ¼” Front Upper and 3 Piece Lower Bypass/Shock mounts
“Tattoo” Front Frame Side w/ 3” Ruff Stuff Flex Joint attached to a 1.75x.25 Chromoly Track Bar
Axle Side Track Bar/PSC Hydro Assist (Hazardous Concepts)
T-Case High/Low Shifter
Lowrance in Dash Touch Chart Plotter, VHF Radio (single piece)
CB Radio on Sport Cage
Lowrance Sonic Hub under Passenger Seat
Lowrance/Sirius Antenna Mounts
Rotopax 4 Gallon Fuel Tank on tire carrier
VHF/CB/Lowrance Weather/Sirius Antenna Mounts
Power Steering Reservoir Passenger Side
ARB under hood 45 degree mount
Hi-Lift Jack on OEM cage Mount
Fire Extinguisher on OEM cage Mount
Decorative Phlexor symbol on Rear Tire carrier
Description
This is KRAWLZ. I built this Jeep for one purpose, to crawl everything... This Jeep shows signs of wear and tear, like scratches, scuffs, scraps, tears and dents from awesome places like MOAB, Johnson Valley and nearly all of my back yard, the Colorado mountains. (Wish I would have gotten to Arizona/Nevada, Krawlz still needs to conquer the Rubicon!!!) This Jeep is 6300 lbs with 40" tires, 5.5” of lift, Front/Rear 3 link with frame side bushings, so it drives as such on the highway and around town...
I promise you, you will never treat this Jeep harder that I’ve treated it. That may come as a shock… OMG he wheeled the piss out of it and put it away wet!.. Na, I wheeled the piss out of it, broke stuff and replaced every broken part with Original or Aftermarket. Every dollar spent on this jeep was premium dollar, never cheeping out (estimated 130k total over the years). If it was broken or not working out, I replaced it. This Jeep is over maintained, I can’t tell you how many parts/items I’ve replaced over the years, no wait I can….
Recent Newly Replaced OEM/Aftermarket Parts
x2 New Optima Batteries (2017)
2011+ Version/Style Hard Top (2014)
Interior Automatic Shifter (2014)
Center Console (2014)
2011+ Windshield with little Jeep decals (3rd one last 2015)
Windshield Frame
Light bar Brackets (Went from Black Ridged to Poison Spyder Painted PVG Orange)
Entire front interior Dash (2014)
EVAC Unit (2012)
EVAP unit (2012)
Rear Ring & Pinion (3rd last 2016)
ATS Rebuilt Transmission (3rd last 2017)
Gauge Cluster (2012)
2nd set of Bushwhacker fenders (2014)
Front OEM Doors/Mirrors, rear passenger door (2014)
Rear OEM Tailgate w/ paint (2017)
3rd K40 Antenna (last 2014)
OEM Radiator Cooler (2017)
3rd Warn Winch Cover (2017)
Rock Krawler Lower link bushings, bushings, bushings…. Every 5k-10k… (2016)
Dynatrac Front Rear Spindles/Bearings (2014)
Dynatrac Front Ball Joints (3rd Set 2015)
PSC Power Steering Pump (2012)
PSC Power Steering Cooler (2012)
Dynatrac Chromoly 4340 Rear Axle Shafts (2012)
Rear drive Shaft (2011 wasn’t the J.E. Reel, now it is)
Front J.E. Reel Driveshaft (CV was clicking)
Lowrance Sonic Hub (2016)
Windshield washer reservoir/assembly (2013)
Delivery available for the lower 48
Old 05-16-2017, 07:01 PM
karls10jk's Avatar
Awesome jeep, she's got the 3.8l with being a 2010, right? Best of luck with the sale
Old 05-16-2017, 08:27 PM
bhardy's Avatar
yeah, sorry typo... 3.8L original motor...
Old 05-21-2017, 04:39 PM
bhardy's Avatar
Lots of Custom Work...
Old 06-12-2017, 09:19 AM
bhardy's Avatar
What do you think of forums and their popularity these days when trying to sell vehicles, seems like social media has more response... Auto trader for this type of vehicle is just plain bad, don't waste your monies there. Anyone want to make an offer on this 110k beast?
Quick Reply: 2010 Jeep Wrangler | 40s | RIPP Supercharger | King Shocks
