06 Wrangler
How bad is the wobble?
I would start with the wheels. Check for damage to tires, missing weights. Then have them re-balanced.
If the wheels and tires are good and balanced, check alignment, check for bent axle, worn/bent steering and suspension components (bushings, tie rods, tie rod ends, steering stabilizer) replace as needed.
If everything is aligned and tight (not worn out) a stock undamaged TJ should be good to go.
Good luck.
Good luck.
