Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
body lift question
Old Sep 30, 2009 | 06:43 PM
tots's Avatar
Default body lift question
i have a 2" spacer lift right now. is it possible to put a 2" body lift on my jeep with the spacers? if so what else would i have to do? thanks.
Old Oct 8, 2009 | 08:17 PM
davidwm71's Avatar
Yes... one has nothing to do with the other. Won't be a problem at all.
Old Oct 8, 2009 | 09:09 PM
JPTwinz's Avatar
x2.....body lifts fit between the frame and the body tub via the body mounts located around the Jeep.
Though be weary of a 2" body lift. The gap it creates can be quite visually horific! With your current set-up, you may be just as well off with a 1" BL depending on what size tire you will be running, etc.
Old Oct 9, 2009 | 01:35 PM
Shadowman890's Avatar
If you did a 1" body on top of a 2" lift, would you still have to do the sye and all the other mods associated with bigger lifts on TJ's?
Old Oct 9, 2009 | 01:53 PM
JPTwinz's Avatar
Lifting the body has no effect on the drivetrain. On the older TJs and YJs you had to lengthen breather hoses, gas lines, etc - essentialy anything attached from the body to the frame. But on the JK, a 1" BL isn't enough to have to make any of those modifications. SOme guys with a manual transmission have had to do some things with the shifter but nada for the automatics.
