Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
HELP - YJ 4wd problem!
Old Apr 11, 2007 | 06:52 PM
BillX4's Avatar
Angry HELP - YJ 4wd problem!
Hello...
I have a problem, a big problem... I own a 95YJ, a 97TJ and on 07JK and am selling my YJ to a friend.... it has always worked fantastic, until TODAY!
So in 2WD it works fine, (It is an automatic 4cyl) and when you pull back the lever to go into 4WD it behaves normally (No extra effort needed or anything) and then when you start to accelerate, around 20MPH the whole vehicle starts to rumble (like vibrate and shake sortof) and it does not normally do this... until today. So when you push it back into 2WD it takes longer than normal for the light to go away and there is a noticeable THUD! and it's back in 2wd... please help, any thoughts?
I just checked the transfer case and made sure that it was topped off with fluid and that seems all good, I also jacked up the front end in 4WD and spun the tires and the other one will spin freely in reverse just fine (if that helps) thanks in advance!
Old Apr 12, 2007 | 05:22 PM
BillX4's Avatar
tomorrow night I am going to have it in a garage so I can take a better look (instead of my driveway) and I will take a look at that, i really appreciate any direction so thank you!
Old Apr 13, 2007 | 11:04 AM
SabrToothSqrl's Avatar
Default agree
I agree; the front drive shaft on the YJ only spins in 4WD.
Also check the front hub lock / unlock vaccum system, I have heard it is problematic on the YJ...
