Jeep TJ & YJ WranglerOverall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
Heya guys got a 2004 wrangler 3 inch suspension 2.5 body lift. Lot of rattling lately think I found the problem. What is this and any solutions? Thanks! Also had death wobble at 35 mph.
You're asking your question about a TJ on a JK forum. There are some differences, but recommend you skulk around Google for info on the TJ front swaybar links. You're missing a bushing that should be there. Might be available from manufacturer of your lift. Might be better to just replace both links (one on each side): The other is probably getting pretty worn, too. FYI, with your lift you're going to want to get one of the proper length, if you decide to replace. But, here's a sample of what's out there ...
