Spider LJ
Alright.. the moment we have all been waiting for
The Jeep is finally in the shop for the following to be installed!
(I'm copying my ticket on here) this build will take about a month or so from start to finish! more pics as things progress.
PARTS!
* AIR LOCKER JK RUB 35SPLINE
* R&P JK RUB FRT
* BRAKE KIT JK FRT
* HUB BEARING ASY
* KNUCKLE JK LEFT
* KNUCKLE JK RIGHT
* TIE ROD JK
* AIR LOCKER D44
* R&P JK RUB D44 REA
* AXLE KIT JK D44R
* MISC
* COMPRESSOR COMPACT
* BALL JOINTS JK D44
* SPRINGS TJ FRT HD
* SPRINGS TJ REAR HD
* SPEEDBUMP KIT TJ F
* SPEEDBUMP KIT TJ R
* 5160'S
* TRACK-BAR BRKT TJ
* 37X12.50R17 MT/R K
* AEV HIGH LINE KIT TJ
* RCV SHAFTS
* TERA SWAY BAR ST DR TJ
* DRIVE SAHFT
* YOKE JK D44 32SPLI
* AEV TIRE CARRIER JK
* TRACK BAR JK FRT
* PAINT JEEP
PARTS!
* R&P JK RUB FRT
* BRAKE KIT JK FRT
* HUB BEARING ASY
* KNUCKLE JK LEFT
* KNUCKLE JK RIGHT
* TIE ROD JK
* AIR LOCKER D44
* AXLE KIT JK D44R
* MISC
* SPRINGS TJ FRT HD
* 5160'S
* TRACK-BAR BRKT TJ
* RCV SHAFTS
* DRIVE SAHFT
* TRACK BAR JK FRT
* PAINT JEEP
Thanks.. I'm excited
here are some pics..
check out the welds on the front axle :2thumbsup:
Here is the front pretty much all mocked up minus the C gussets. that we will be doing next week
my LJs guts all out
you can see that the tranni is out.. sent it to check the Syncros. well it turns out that the tranni needs a rebuild
first second and reverse gears are shot.. all syncros need replacment and this is gonna cost an extra 1300
:thumbdown:
we should have the tranni back Monday or Tuesday at most.
The rear Axle is also out
at this point we are waiting on the tranni to comeback so that we can install it. After the install we can adjust the pinion angle of the rear JK 44 and weld the truss. after that both axles go to sand blast! then powdercoat.
Parts on back order:
-Teraflex Swaybar system - thought of the Curries but they are too soft and offroad only :thumbdown:
-37" MTRs (i'm thinking of going to 37" BFG AT KOs) what do you think?
-Dynatrac Balljoints
Thanks and stay tuned for more
my LJs guts all out
:thumbdown:we should have the tranni back Monday or Tuesday at most.
Thanks
so I had some free time and decided to show some pics of whats going to be installed.
Here we have the front hub and bearing assembly
5:13 Yukons
TeraFlex big brakes
AEV High Line kit
OME Springs (not sure, might change them if they don't workout)
ARB compressor for the lockers
ARB 35spline lockers
Bilstein 5160s
Chromoly tierod
Custom Driveshafts (we need to take some measurements for this and probably will be the last thing to get)
Superior 35spline axle shafts
Kilby AEV highline rockers
Luk pro gold clutch
MTRs
OME trackbar relocation braket
Dynatrac ProSteer ball joints
RCV shafts
Reid JK knuckles
to be continued....
Savvy taillights
Teraflex front trackbar
Teraflex front speedbumps
Teraflex rear speedbumps
Daystar switch panel
Besttop windows
Thats all for now.. I know i'm missing bumpers, lights and a winch.. those will come in last
your welcome to any suggestions or comments
Savvy taillights
Besttop windows
