Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
TJ lift and driveshaft question
Old Oct 14, 2008 | 05:11 PM
tn_dodge's Avatar
The tcase is mounted to the skid, so when you drop the skid, the tcase comes down with it. Reduces the angle, reduces driveline vibration. The reduced angle removes the need for a cv joint driveshaft, but it does it at the cost of losing ground clearance. If it is going to be an off-road rig, go with the SYE and the cv shaft. Stronger and increased clearance underneath. My .02, anyway.
Old Oct 15, 2008 | 07:47 AM
JK-Q8's Avatar
Thanks tn dodge. i think i will go with the sye since its not too pricey.
Old Oct 15, 2008 | 05:38 PM
tn_dodge's Avatar
You are welcome
Old Oct 29, 2008 | 03:00 PM
Augie's Avatar
Tranny skid drop will also require you to adjust the linkage on your transfer case. Any lift manufacturer will have them.
