where to get OEM soft top hardware items
I need a few OEM items for a factory TJ softtop (from an '04 TJ) I bought on eBay that was missing a few items. What's the best place to find these parts at the best price?
I need:
* all 4 screws/pins for the door surrounds
* left/right roll bar brackets for the soft top bows.
* left/right tailgate mounts for the rear window bar.
Thanks !
I need:
Thanks !
i got the rear bar brakets at a junk yard. the screws--you may be stuck with ebay.
FYI on the roll bar mounting points, if the softop came from a 04 tj, you need the brackets from an 03 or later jeep to put the bows in the correct location. -they account for the thicker rollbar padding. if your tj is pre-03, it has the thin padding (if you are still using it). the post-03 brakets will fit under the thin padding with a "little" stretching!! (trust me). if your tj is post-03, the brakets will fit like a glove and nothing to worry about! Good Luck!!
