JK Accessories & Misc Parts This forum is dedicated for the selling of miscellaneous parts and accessories for the Jeep JK Wrangler. This would include things such as cold air intakes, seat covers, soft-tops, bikini tops, interior trim, air compressors, lighting, trail gear, etc.
FOR SELL AEV ProCal Module
Old Mar 4, 2011 | 04:50 PM
cmyjeep's Avatar
Default FOR SELL AEV ProCal Module
SOLD AEV ProCal Module .
MORE INFO.
AEV's ProCal Module is a hand-held powerhouse! This essential tool
provides JK owners an easy, low-cost way to make a variety of useful
changes not offered by the dealer or any other re-programmer. Topping
the list is the ability to correct the speedometer and gear ratio when
larger tires are installed. With the speedometer left uncorrected,
there is a major degradation in the performance of the stability
control (ESP), transmission shifting, and engine performance.
The best part of the ProCal is that it isn’t just for correcting the
speedometer. The Tire Pressure Monitoring System can now be
recalibrated to better suit aftermarket tires without triggering the
dash light. Further, the ProCal Module makes it possible to activate
daytime running lamps, "one-touch" turn signals, enable a temporarily
increased engine idle speed for winching, clear engine codes, and even
has a feature to help align the vehicle perfectly for optimal ESP
performance.
The ProCal Module is equipped with a series of easy-to-use DIP
switches. By reading the simple Quick Reference Guide included with
the ProCal module, a user can quickly dial in a code for the desired
recalibration. Once the DIP switches are set, simply plug the Module
into the vehicle's OBDII. The whole process can be completed in mere
minutes and it's just as easy to restore the vehicle back to its
original settings with the ProCal.
SOLD
Old Mar 4, 2011 | 04:54 PM
Rafi's Avatar
ill take it, i emailed you
sold in 4 minutes... record? haha
Old Mar 4, 2011 | 05:05 PM
cmyjeep's Avatar
ok i will see what we can do to get it mailed to you.
Old Mar 4, 2011 | 05:15 PM
cmyjeep's Avatar
HI Rafi
I HAD to send you a pm my e-mail acc. wont open at work for some reason.
Old Mar 4, 2011 | 05:40 PM
husker_fan's Avatar
I call second in line!
Old Mar 4, 2011 | 06:15 PM
cmyjeep's Avatar
husker_fan i sent you am pm. my e-mail wont open here at work
Old Mar 5, 2011 | 01:55 PM
rich e dee's Avatar
Dammit I missed another one!
Old Mar 14, 2011 | 04:54 PM
husker_fan's Avatar
AWESOME SELLER!
Works great, terrific purchase!
