Led Lights help
So I installed a pair of 5 inch roun lights and mounted them on the windshield mounts. Have had them for about a month and worked perfectly, I recently got a winch and after I hooked up the winch now my lights won't turn on. But the light in the switch lights up. I've checked the fuse and undid the wiring of the winch and they still won't work. Could I have shorted them out? I'm honestly lost at this point and am not sure what to do. Thanks for any help you have!
You'll need some wire to do this, but, take one of the connectors apart and hook it straight to your battery. (The light side connector, not the harness side). The light should come on if it's any good.
