JK Axles, Gears & Drivetrain This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
Axle Shafts, shocks, bumper, Carriers, spider gears, gears, tow hook.
Old Oct 16, 2012 | 09:18 AM
moabjk072d's Avatar
Default Axle Shafts, shocks, bumper, Carriers, spider gears, gears, tow hook.
Used Dana 44 open carrier with spider gears (Will fit 3.73-5.38 gears) $50
2 Used front Dana 44 Rubicon drivers side inner and outer front axle shafts $100
2 rear used Rubicon axle shafts $50 each
Used set of Dana 30 spider gears.$50
Used rear factory JK bumper $50
Rear Factory tow hook $20
Used rear 4" lift shocks for 2007-2013 Wrangler $20
Located in Pleasant Grove, UT 84062
ID:	384620Click image for larger version
ID:	384621Click image for larger version
Old Oct 16, 2012 | 12:24 PM
Highrollintruck's Avatar
Originally Posted by moabjk072d
Used Dana 30 and Dana 44 open carriers with spider gears from 2010 Jeep Wrangler JK Mountain edition.(Will fit 3.73-5.38 gears) $50 each
Used Dana 44 4.10 gears from 2010 front rubicon JK44.$50
2 Used front Dana 44 rubicon drivers side inner and outer front axle shafts $100 each
Drivers side Dana 30 front axle shaft for 2007-2013 Jeep Wrangler $100
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=373881"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=373882"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=373883"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=373884"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=373885"/>
Is the Dana 30 still available?
Old Nov 19, 2012 | 08:02 AM
dipstickinva's Avatar
you still have the Dana 30 carrier? if so how much for shipping to 23437. I have money on hand.
Old Nov 19, 2012 | 11:19 AM
TINMAN_2469's Avatar
Looking for both carriers if front is not taken. Shipping cost to 30005.
Old Dec 5, 2012 | 01:26 PM
moabjk072d's Avatar
Updated the list again and a bump to the top.
