JK Axles, Gears & Drivetrain This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
Front Rubicon 44
Old Oct 9, 2012 | 08:18 PM
moabjk072d's Avatar
Default Front Rubicon 44
Rubicon 44 HOUSING it is out of a 2012 MW3 Rubicon with 1,500 miles on it and in like new condition. It has never been wheeled, it was traded out for a Tera44 housing.
It is the lower one in the picture.
$700
ID:	376246Click image for larger version
ID:	378119Click image for larger version
Old Oct 9, 2012 | 08:32 PM
Tanner6427's Avatar
Where are you located? How much?
Old Oct 10, 2012 | 08:26 AM
Tanner6427's Avatar
Sent you a PM
Old Oct 11, 2012 | 11:17 AM
tayconjk's Avatar
PM sent your way
Old Oct 12, 2012 | 03:38 PM
Xodius's Avatar
It is geared? If so what set is in it?
Old Oct 12, 2012 | 07:56 PM
moabjk072d's Avatar
It is just the housing, bearing caps and diff cover but I do have a set of 4.10 gears I can throw in with it.
Old Oct 15, 2012 | 03:26 PM
v8zracer260z's Avatar
Veteran: Marine Corp
Could you check shipping to 32609. I'm looking for an assy but may have to build one and this looks like a good starting point.
Old Oct 16, 2012 | 08:21 AM
moabjk072d's Avatar
It is a excellent starting point and exactly how I started my first front D44 pictured above, I am into it way less then a Pro rock 44 with the same results.
My Zip is 84062 and the crate is 23" tall x 21" wide and 60 and 1/2" long, with crate and everything I estimate it to weigh around 140lbs max.
Old Oct 16, 2012 | 09:26 PM
DEMNJK11's Avatar
Originally Posted by moabjk072d
Responded to both pm's.
Just a FYI, Dealer cost new is $1,400 and Teraflex sales used ones for $1,000. and this one is in NEW condition but I am not looking to get a thousand out of it but somewhere close to that is what I would need to let it go.
???what dealership quoted you that for a whole new axle?
Old Oct 16, 2012 | 11:06 PM
JeepJKer's Avatar
It's just the housing. No gears no locker no axle shafts.
