Stock 2012 and up 2 door JK Auto driveshafts front and rear
Hello
For local pickup ONLY
I live in Mission Viejo, CA
I did a lift on my 2012 2 door JK Rubi Auto at 10k miles.
I removed the front and rear driveshafts and replaced with aftermarket when I did the lift.
These driveshafts are in excellent condition. As you can see I have the yokes from the differential sides and the transfer case sides as well as all the bolts.
$75 for front, $75 for rear, OBRO.
Thank you for looking.
Hello
$100 for front, $100 for rear, OBRO.
Is the rear a different length than a 2007 2dr JK manual? I'm in need of a stock rear driveshaft and am in Patterson, CA
So very sorry that I didnt see your post until now.
I am not sure if the length is the same or not. I would guess its different between an auto vs manual. Ultimately, if you like, take a measurement somewhere where I can duplicate it, and Ill see...otherwise, I would suggest touching base with the dealer. See if the part numbers are same between the 2.
Best,
D
Best,
D
Check out the teraflex high rzeppa joint replacement, it saved mine and was way less expensive than buying a new driveshaft :-) they have a great YouTube video on how to do the install too.
