JKU Red Rock Fab Sliders
I have a set of Red Rock Fab sliders for sale. They are frame mounted using bolts or they can be welded on. They could use a fresh coat of powder coat or paint. These things are solid. I only took them off because they will not work with the rear clayton long arm. SOLD
When bolting them to the frame they use the 3 stock bolts hoding the skid plates up on passenger side. With the driver you use the front 2 bolts then you drill 2 holes in the center of the frame, above the bolt holding the transfer case skid. The rear mount on the driver side uses the body mount and for the bottom you need to drill. Take a look at your frame you'll see what I am talking about.
