Another Cobra 75 WXST Install....with a twist!
Old Dec 27, 2011 | 07:36 AM
vulcan classic's Avatar
Originally Posted by RHD-Manx2
How is the sound quality with this radio?
I'm waiting for my antenna, cable, and side mount, should be here today. I'm going with a 4' Firestik Firefly antenna with the Firestik side mount attached to license plate holder. I ran a solid copper 12AWG wire for the antenna ground through the LR tail light housing down to the rear brake line bracket bolt for good frame ground. i will run the antenna coax cable up through the wheel well grommet and under the carpeting in cargo area, across and down passenger side to glove box area.
I'll also run an external speaker cable from the CB control box to AUX jack on stock head unit if the sound quality of the handset is inadequate.
Old Dec 27, 2011 | 07:56 AM
Stillmotion's Avatar
Didn't think about doing that with the radio... sounds like a plan to me.
Does the mic clip come with the cobra or did you buy it separate?
Old Dec 27, 2011 | 09:26 AM
Yes clip comes with the CB. If you plan on running external speaker jack to stereo, look for a mono jack, i.e. tip/sleeve jack so you get both L/R speakers to work; I have a stereo mini din 1/8" cable but it only gets sound to left side, I'll have to find a mono cable too.
Old Dec 27, 2011 | 02:45 PM
ScubaDude's Avatar
This just saved me about a week of research on cb radios. I now know what type of CB I want and where I'm installing it. Thanks man
Old Dec 27, 2011 | 03:03 PM
sringer's Avatar
It is superb. I have this cb as well. Mine I mounted in my center console
I am here: http://maps.google.com/maps?ll=48.427066,-114.347183
Sent from my iPhone 4s using Verizon 3G
