Antenna Cable Question
Old Nov 25, 2017 | 10:28 AM
dmwil's Avatar
Default Antenna Cable Question
Is there any advantage to a shorter or longer antenna cable, or is it a wash, given a correct tune for each?
I'm deciding which side of my Jeep to run the antenna cable to my new hood antenna mount. I'd like to go 9' and run it through the driver side firewall, but I've already got cables crammed in there from auxillary lights and I'm not sure I can squeeze even the low profile connector through it. The passenger side would require an 18' cable, but that firewall opening is wide open, so I know I could easily run it through there.
I want to know if there is an advantage to either before I make the final decision as to which to order.
Old Nov 26, 2017 | 01:37 PM
OldHippie's Avatar
Default Cable length
I've always found that the 18 is easier to tune.
Old Nov 26, 2017 | 03:48 PM
dmwil's Avatar
Thanks! I ordered the 18. It will be easier to run and tune.
Old Dec 2, 2017 | 09:31 AM
Mark Doiron's Avatar
That's likely because the antenna was better placed, with some contribution from loss in the cable. The best way to tune an antenna is to completely bypass the cable, usually by using an antenna analyzer (which in its simplest interpretation is an SWR meter with a built-in RF emitter so you don't need to use the original radio and can bypass the cable completely by attaching the analyzer directly at the antenna). To consider the cable loss aspect, pretend you hooked your 5 watt transmitter up to a 10,000 foot run of cable with no antenna. That cable will swallow up the RF--you'll have amazing SWR with virtually no reflected power--and won't be putting much of a signal out at all.
