Antenna mount question
1 Attachment(s)
Anybody used the Quadratec stainless steel fender mount like the one in the pic below? If so have you had any serious issues with it interfering with the factory radio antenna on the other side of the cowl?? Was curious who's running this setup and their opinions of mounting my antenna there...thx in advance
Don't have that mount, but my antenna mounted in that location.
Works pretty well there. |
Excellent! You don't get any interference with the stock fm antenna location? I've read and done a little research that if its mounted too close it can cause a little RF inside the jeep and you can hear it thru your speakers. I'm a CB newb and want to make sure I'm putting my money to good use. That mount is a little expensive but it does come with the coax mounts and light weight Firestik antenna so that's a plus I guess...
Be sure that mount is grounded really good, run a ground wire to one of the mounting screws.
I have my two meter ham radio antenna there. Great mount. The spare tire location is horrible. Stay away from that area.
Okay thx folks for the suggestions looks like I'll keep it near the hood when I'm ready to install
Originally Posted by MrKenmore
(Post 4182721)
10:14 if not forwarded automatically ... https://youtu.be/49D7YupyDBY?t=614 |
Uh yeah it's getting a little tight Haha, to say the least.
PS> It does go to 10:14, great video as always Mark. :thumbsup:
(Post 4182899)
It is about the worst possible place on the Jeep, isn't it? However, it is the best possible place on the Jeep if you drive through narrow ways with lots of brush, because beating up your antenna until it doesn't work is worse than have high SWR limiting your radio to a half mile out or so--at least for what I routinely do with my Jeep.
1 Attachment(s)
(Post 4182721)
For a CB, just leave it there. Make sure the mounting point is isolated properly from the antenna. I had a reading of about 3 initially. I drilled out the mounting point hole a bit to give additional clearance and the SWR went to 1.1.
