antenna size
Old Jan 14, 2011 | 04:46 PM
joe002's Avatar
3 foot Firefly - less banging into stuff.
Old Jan 14, 2011 | 04:57 PM
vandegrift's Avatar
4' Firestik II tuned and works great
Old Jan 14, 2011 | 05:23 PM
rinkishJK's Avatar
It seems 4' is the common size.
Old Jan 14, 2011 | 05:52 PM
adrom's Avatar
just got a 4' firestik for free. cant beat it
Old Jan 14, 2011 | 06:29 PM
AK4Dave's Avatar
How would you know......have you tried everything else...???
Old Jan 15, 2011 | 07:31 AM
Highlander's Avatar
Default same spring problem
Originally Posted by ilflyya
Just got my 4' Firestick II (Tunable Tip) from Northridge4x4.
My current 4' Firestick KW is stuck to a spring mount on the spare tire...can't get it off for nothing! Beware of the spring, although I thought a Spring would be best to provide some "give". When I go to twist off the antenna, the connection just rotates inside the spring. I ran that spring for two years with no issue, now it's junk. Going to a quick disconnect now,
Anyway...enough of that, this is an antenna thread ;-)
Oh, and I'll be doing Toad's homemade antenna holder mod that goes inside, above the rear window
My first spring did that, it is a drag it is still on the quick disconnect!! Ended up getting a new spring and disconnect and put a lock washer in between, and don't tighten it up as much. Oh- I use a 4' Everhardt ,or 102" whip.
Old Jan 15, 2011 | 07:44 AM
09DARKORANGEJK's Avatar
Plus Series 6000 Watt Trucker Antenna - Black/Clear with Chrome Coil from the antenna mount to the top of the coil its is about 12" then a 48" tunable whip slides into the top
Old Jan 15, 2011 | 07:58 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Running a 4' Firestik on a CoolTec Ultra mount.
So far So good.
Old Jan 15, 2011 | 08:19 AM
Wolf Moon's Avatar
Default Function vs. Appearance
Last weekend, installed the CoolTech Ultramount set-up with the 4' Firestik II and a Cobra 75 WX ST, and I just spent the entire week trying to figure out why my SWR was so frickin' high. When I say "high", I mean as far peaked into the "red zone" as you can be. I sanded the paint off behind the tail light like they say, and I even ran an additional ground wire from the mount bracket to the frame, but the SWR was still way too high. I could receive from about a mile, but couldn't transmit beyond a city block. I discovered that my tail light guards were causing some interference, but they weren't the main culprit of my high SWR. After using every curse word in the dictionary (twice!), I took my Jeep to the local CB shop, and they hooked me up with a new antenna (Wilson 2000 Trucker Whip). While it doesn't look nearly as badass as the Firestik, it definitely does a better job. Now, my SWR is a little over 1.5, which still isn't great, but it's definitely an improvement, and I'm a firm believer of function over appearance. I do like the "factory" appearance of the CoolTech, but when mounting near the license plate and so close to the body with a fiberglass antenna, I was just getting way too much interference for whatever reason...
Old May 3, 2011 | 04:23 PM
dcirate25's Avatar
Originally Posted by JK719357
Go with the 102" stainless steel whip! Cant beat it!
Where do you mount yours? I just got one today.
