CB Radio interfering with oil pressure gauge??
Old 11-27-2011, 08:32 AM
gadget799's Avatar
Default CB Radio interfering with oil pressure gauge??
So i installed the Glow Shift Oil Pressure Gauge and Adapter awhile ago and the other day i went to use my CB Radio and everytime i key up the Mic the Oil Pressure Gauge drops to 0 and when i un-key the Mic it returns to normal ??? .. i have double checked the ground connections and all associated wiring and have become stumped ...
Anyone have any ideas for me to try ...Thanks
Old 11-27-2011, 10:37 AM
AK4Dave's Avatar
Is it a wire sensor to the gauge? If so wrap the wire around a ferrite as close to the gauge as you can get. Radio shack should still carry the ones that come apart so you can wrap a wire around it. That should do the trick.
Or you could try rerouting either the coax or gauge wire.
Old 11-27-2011, 11:24 AM
gadget799's Avatar
Already tried re-routing the wires and coax .. but will try the Cable Ferrite next , Thanks
Old 11-27-2011, 12:52 PM
SlowJK's Avatar
Take the positive and neg wires of the cb and twist them together and wire it directly to the battery. You can use alum foil to shield the wires as well. The signal wire and the cb wires should not be close to each in anyway.
Old 11-27-2011, 03:04 PM
rpaulson's Avatar
????? what ??????
Old 11-27-2011, 03:21 PM
gadget799's Avatar
The wires are not routed anywhere near each other ... CB is mounted on the roof (overhead console) Cb power/ground wires run down passenger A-Piller, coax runs along passenger roll bar to rear of jeep....Oil Sensor wires run through drivers side hole in fire wall to sending unit ... CB is connected to AUX Battery, Oil Pressure Unit runs off main System ..
Tried the Cable Ferrite Trick with no luck .. Tried Separating Coax apart from CB Power wires, also no luck ...
Old 11-27-2011, 04:41 PM
AK4Dave's Avatar
Did you put the ferrite as close to the gauge as possible?
Old 11-27-2011, 05:21 PM
rpaulson's Avatar
maybe RF from poor antenna ground. Got a few pics of your antenna mount?
gadget799's Avatar
managed to get the ferrite right up against the gauge cup - as close as its going to get ..
Old 11-27-2011, 05:25 PM
gadget799's Avatar
thats my next plan of attack ...
I run a 102" Whip with a light duty spring on this mount
Name:	Antenna Mount 2.jpg
ID:	242651Click image for larger version
Name:	Antenna Mount 1.jpg
Quick Reply: CB Radio interfering with oil pressure gauge??
