Best location for CB antenna?
Old Dec 7, 2011 | 06:41 PM
  #21
JKR's Avatar
JKR
Originally Posted by Hook-Em
I like mine. I can remove the antenna and nobody would ever know I had a CB unless they snooped around. Here are some pics.
Attachment 237310Attachment 237315Attachment 237314Attachment 237311Attachment 237312
Who makes this CB mounting bracket?
Old Dec 7, 2011 | 06:56 PM
  #22
Sharkey's Avatar
Originally Posted by realjeep
Also one cant open the back window and have the tailgate closed it hits the antenna that is a minus too.
You can open your window without first opening the tailgate? Maybe I'm missing something here, but that is impossible with my Jeep.
Old Dec 7, 2011 | 07:17 PM
  #23
azrwilkinson's Avatar
Best place is on an OR-Fab tire carrier, thats where I put mine!
Old Dec 7, 2011 | 07:44 PM
  #24
Sunshadw's Avatar
Purchase a Hanson bumper & carrier and the CB mount is built in.
Old Dec 8, 2011 | 06:01 AM
  #25
8000ft's Avatar
here's the same mount as Hook-Em has, the nice thing is that the coax is completely inside the vehical. SWR of 1.2 to 1.4Click image for larger version
ID:	247215Click image for larger version
Name:	2011 04 25_0001.jpg
ID:	247213Click image for larger version
Name:	2011 04 27_0015.jpg
Old Dec 8, 2011 | 08:56 AM
  #26
WhiskyPirate's Avatar
Originally bought the Cooltech gatemount setup but when I went to install, there wasn't enough room between the gate and my RR tire carrier. My buddy had a Teraflex mount and that couldn't clear either. So I took his Tera mount, drilled two pilot holes in the RR carrier and then mounted my antenna there. Has worked like a charm.
Old Dec 8, 2011 | 11:59 AM
  #27
jfleur91's Avatar
This is the one I am going with ! what size antenna you run?? would 4' be enough?
Old Dec 8, 2011 | 12:03 PM
  #28
jeep_creep's Avatar
Hood mount is the best place for jeeps because they need a big flat piece of metal to bounce the radio waves off that's where mine is and it works better than all my buddy's with there's on the back
Old Dec 8, 2011 | 12:10 PM
  #29
Work in Progress - JK's Avatar
I also have a 4' Firestick, and found that if I installed it on the tire mount or the lic plate mount it would hit the garage door. I have off road bumpers and just drilled a hole, spray painted it with black flat (like I do after wheelin' into rocks and trees), the hole was positioned between the rear door 'when opened' and the taillight, so no interferrence, and the wire runs down and back up thru the back of the right taillight housing (remove same to access) and forward thru and under the side cab lip to the front - works like a dream!
