Brake Light on when using CB
Old Feb 23, 2009 | 03:57 AM
RedneckJeep's Avatar
Originally Posted by goldtr8
When caravaning with a group of Jeeps yesterday it was commented to me that when I am talking on my CB the 3rd brake light goes on.
I routed my coax along the wires going into the tailgate and zip tied them all together. I assume the power wire for the brake light is in this loom.
Does it make sense that energy from the coax could light the brake light.
I've seen 4 watts light up a flourescent light bulb, so I'm bankin on RF. I'd check the wiring to be safe, but other than that, damn if I'd worry about it.
Old Feb 23, 2009 | 04:17 AM
renegadelt1's Avatar
The trouble is if he used the CB on the street there could be a problem with other drivers
Old Feb 23, 2009 | 04:40 AM
Yeah true....but does he NEED it on the street? If so, then he probably needs to move the antenna. ......perhaps like a lot of other people.
Old Feb 23, 2009 | 10:51 AM
Fermin's Avatar
Just add a sticker to the light that reads "On Air"
Old Feb 23, 2009 | 02:47 PM
I LIKE IT!
Old Feb 23, 2009 | 04:00 PM
goldtr8's Avatar
Don, Is the antenna really close to the light? it sounds like you setup is right on the money.
Its real close to the light.
But maybe it is a good thing for getting moving tailgaters.
I will be checking grounds again this weekend. Right now it is in the garage until I can clean it out from the trail run this last weekend.
Old Feb 23, 2009 | 04:59 PM
boots's Avatar
I would get power from another source. Like maybe the rear wiper/washer that way on you talk on the CB at least you'll have a clean rear window. Hope you find your problem.....
Old Feb 24, 2009 | 04:13 AM
N2MWL's Avatar
Just curious, how much power are you running ?? As stated above it sounds like stray RF which is not your friend..
I would start by running your power and ground from the radio directly to the battery, then a chasis ground from the back of your radio to the frame of the Jeep certainly wouldn't hurt either....Another ground from your antenna mount to the Jeeps frame would also be a good idea....If your running an amp I suggest you stop until the entire Jeep is properly grounded before fry the Jeeps computer with stray RF....
73
Mike (N2MWL)
Old Feb 24, 2009 | 03:28 PM
goldtr8's Avatar
I'm thinking its because I have the coax running along the wire that feeds the brake light and have them zip tied together.
But I am not an electrical engineer so the stray RF thing is not something that I understand, much less how to find out what it is.
Isnt the dash plug wired directly to the battery already? The reason I ask this is because when I was using a hand held unit plugged into the switched plug when talking it would drive the guages crazy and when plugged into the battery one everything was fine. Since I installed this CB I have tried both plugs and neither one has driven the guages crazy. But I only plug the new CB into the battery one.
Anyway I have some checking to do this weekend. So if you guys can explain stray RF it would be appreciated.
Thanks
Old Feb 24, 2009 | 07:40 PM
CIJeep's Avatar
Get a lens that reads, "ON THE AIR".
